Re: newb with questions (possibly purchasing ty)
crazyidiot4.8 said:
first off, hi and great site you have here. i'm getting rid of my current truck and looking into possibly buying a tyhpoon. i need to know some common problems or areas to look at when shopping.
http://www.syty.org/old/buyers.html
http://syty.net/phpBB2/search.php (this topic comes up a lot)
http://www.syty.org/faq.html
any major mechanical issues?
depends on the truck and how it was maintained and mileage. Fuel pumps, transmissions, engines......any one of them could be on its last leg. These trucks are 12 years old now at their youngest, so you have to expect 13 years of normal wear and tear, plus multiply it by the fact that its a performance vehicle.
lower back corners of the fenders are typical for all S-Series trucks, but generally anything behind the cladding is usually more prone to rusting.
Also, around the back window, usually at the top, is a very common spot for it to rust out.
also around the back window, the weather stripping tends to leak over time. Also, there are little spongy seals around where the hood hinges dip into the firewall. A lot of times those are missing or torn, causing leaks behind the dash in the firewall.
anything you think i should be looking for. also typical problems you guys run into during the life of your vehicles (burning oil, sensors goin out on regular basis, etc).
transmissions, fuel pumps, engines :lol: those are the trypical problems with these trucks. That, and they need frequent tune ups (plugs, cap, rotor, sometimes wires) to keep them running well. Valvestem seals leak on many trucks, but its not a major issue. Unfortunately, the little cheap stuff tends not to be an issue with these trucks as much as the really expensive time consuming stuff.
i prolly won't do much modding (poor college student) so thats not much of a concern. thanks for any help 8)
with that comment alone, youre going to get a lot of people telling you not to buy one now. You might be able to buy the truck, but its going to get expensive maintaining it, especially if its going to be your daily driver in college.
