Oil Cooler Drain
Dr.Evil
Addicted to Boost
How do I drain the oil out of the cooler when changing the oil? If I let it get pretty black before I change it, I drain all of it out of the crankcase and put some fresh in, after firing it up it looked used because I didn't get all of the old stuff out of the oil cooler and lines. Is there a dran somewhere or should I not even worry about it and just change it more often? thanks
jwaller
Evil Genius/SyTy Guru
Re: Oil Cooler Drain
bout the only thing you can do is remove the hose on the bottom and force some air in from the top, but like the captain said "don't worry bout it"
