I had an issue when I first got my truck running. I had run -4AN lines to feed the turbos and nice straight -10 drains to each side of the pan. It wasn't enough though as I had oil come out the backside of the brand new turbo on the pass side.
After some research I found this to be a common problem. Some places sell special plates, some people have used NOS jets, but one person suggested tapping the -4AN with a 10-32 thread and using a set screw.
That is exactly what I did, tapped the fitting part way (that way it can't move down into the turbo), drilled a hole in the center the size I wanted to try first, dab of loctite and in it went.
Best thing is I can change it out for smaller ones later if I find these are still too big, or want to try no restrictor later, etc.
