92 Ty 1173
Ok, so I wanted to pick someones brain at hooters and forgot. Anyway, I got a new melling pump with pick-up tube and shaft from a board member, and with the pump installed the pick doesn't sit parallel to the bottom of the pan to clear it. If I turn it front it will clear the pan and the pan will sit on the block ok. This isn't right is it? Ther screen prolly sits on a 45 to the bottom of the pan.
