Re: Overboost or Detonation (or both)?
Good advice. Does original poster have scan tool? I am not quite sure how he is accurating diagnosing overboost with stock gauge or detonation with out it?
you could take the vacuum hose straight off of the turbo and put it directly onto the wastegate solenoid. This will open the gate up right off the bat, and give you the least amount of boost that the turbo can make. This will at least let you know if its the solenoid, or if you have some other problem. I would only recommend this after you make sure that the gate is not frozen, and that the actuator does not leak vacuum.
