passenger inside wheel lip rubbing on full turn
dpw41285
Spoolin'
stock wheels when i make a hard turn the wheel actually hits so hard it has ground down the aluminum on the wheel, and nocked the wheel weight off. could the truck be out of alignment this far? camber doesnt look horribel but it is lowered in the front and has been aligned since the torsion bar adj. I did have the same problem with the sawblades and i tightend the torsion bars and had the wheel weight taped on the inside of the wheel and the problem went away. Unfortunaltley i thinkt if i raised it this problem would be gone. Any other ideas? Culd the transfercase being locked up promte this as well?
Re: passenger inside wheel lip rubbing on full turn
Don't crank it all the way when you turn? No reason to jeff stuff up if it can be prevented.
MikeRenz
not stock
do you have a stock steering box? the zq8 boxes are able to turn further than a stocker making rubbing easier.
mattw
The most likely cause is that the limit stops on the LCA have worn down over time.. The easiest fix(that I have found) is that clean them up then lay a new weld down on the top of them..
You can see mine in this pic.. I had to build it up quite a bit and then I ground it back down to where it needs to be...
dpw41285
Spoolin'
that is what i needed to know, it doesnt rub with the tape on wheel weight
i will check the steering stop and i do have stock steering box
cloneman315
What are you guys doing with the Zq8 rub?I just dont turn mine all the way
