PCS Electronic Shift Controller Install Q.
tbauer03
TRBOBOX
Where have you guys mounted your computer and where did you run the wiring harness through the floor? I removed the front seats and center console to mock up ideas and now that I played with ideas and seen this in person I figured I would ask before doing anything. The 3 areas I am currently considering is under a seat, under the middle console near the shifter, or on the face of the heater box. I would prefer to keep everything out of sight. I am also curious if anyone has mounted theirs outside of the cab, in the engine bay to avoid cutting a big hole in the floor? I am installing a 4l60E not a 4l80E and the main electrical connector to the trans is on the passenger side.
SY-1193
Re: PCS Electronic Shift Controller Install Q.
My Install takes a little more work but is completely stealth and doesn't cut into any of the storage space in the truck:
>> PCS Install.pdf << approx. 90mb file 37 pages takes a while to load -Adobe .pdf required. (looks like a blank page until it loads)
- I reused the grommet/seal from the stock shifter cable that was no longer used and cut a slit thru it to pass the wiring thru and then sealed it up with surethane. The new shifter cable came with a grommet/seal and I made the hole and everthing match as if GM did it.
-The whole thing fits in front of the storage console and between it and the shifter.
