napa sells replacement fuel line that resembles what is used on alot of newer cars.they have the 2 size o-ring style fittings that can be threaded into the pump and fuel rail, pressure side and return and the plastic line slides over the nipples and comes with crimp style clamps. easy as hell to work with and can be routed easy over the tight clearance bell housing area.
They worked great! after I had My engine and 4l80 in. I made and routed the lines back to the 2 rubber flex hoses by the t-case in about 15 minutes,no leaks and will never rust.
this will help you guys that have fought those old steel lines either over the trans or rusted to the fuel filter or fuel sender.
