Re: plugs wires dist. so many options?
For those that aren't satisfied with the taylors which ones are you using, #74232's? If so, you may wanna look at these #84232 (red), #84032 (blk), I run a set of these with stock acdelco plugs CR42 (gap 0.34"), Taylor cap & rotor, msd ignition streetfire coil, my truck runs like a champ. These wires are way better IMO than stock, msd, and the taylor #74232 (common), they have better ohms resistance per foot than those i just mentioned, they might not be better than the magnecor's but they are 1/3 the price and do the job just fine. Also IMO there is no reason to have a wire more than 8.5mm on a stock motor, you'll never see the spark output versus having major mods or a built motor and needing 10mm magnecor, or moroso
HTH
http://www.summitracing.com/parts/TAY-84232/
