Progress of Bowtie motor
JuStBlAzIN
Re: Progress of Bowtie motor (Not looking good)
Yes I will be at the MotoGp Race racing
I'll be there too. Just need to find a way to get some tickets.. DO you happen to have a hook up on some tickets? I just dont want to pay near 700 for the tickets with pit access.
jhacking
Hacker
The Coating only adds half thou We where checking all the tolorances tonight, and the piston to wall clearence is a little tight, and the mains also. While taking the cam out it was stuck and needed alittle help out. After it came loose the edge of all the cam bearings a sliver of the bearing came off all of them. I will add some pics for all to see of all that has gone on
jhacking
Hacker
The piston coated,and the bare block. all the parts out on the table
jhacking
Hacker
Shot of the cam, and how close the lifter rides on the end of the cam lobe. It will be getting shimed correctly when being put back in. Also note the metal shaving that came of the cam bearing when pulling the cam out?
jhacking
Hacker
The crank after being reblanced. you can see the new weight that was added in either end of the crank, and where it was ground. Also the print out of how much weight it took. Keep in mind the crank was suppose to have been balanced, and the coating does not add weight. Same pistons,rings, rods, balencer, flywheel everything.
jhacking
Hacker
Just a couple more shots of the Uncoated rod bearings, and how bad they looked.
Ty 1885
WoW those bearings looked like they had trash/durt in them. The person (we all know who) did not clean parts properly. As far as balance, there is NO excuse. You HAVE TO get some of your money back form the so called engine builder!!!
jhacking
Hacker
I'm pretty much done talking about this I would like to move on. He has called me a lier and insisted that the people that are working on my motor now dont know what there doing. Dont forget these motors where raced by these people for years in the Bush Grand National seiers I think they know what there doing.
blk00z28
Forced to by choice
The company is Calico Coatings they are 3 min down the road
Damn look at the size of those ports on your heads :eek:
Glad to see things are moving forward. I'll have to check out that company for the coating Jamie. Thanks for posting the name. I'll look them up. :tup:
Ry368
one mile = 5280 feet
Cool....they recoated the bearings for my zr1 and havn't failed me yet!:tup:
jhacking
Hacker
Re: Progress of Bowtie motor ( looking very good)
Well just a update of my motor after I have had to completely redo the engine after Waller Performance had screwed it up.
The motor was just minutes away from going on the dyno and that was at 12.00 today.
This has been a long project that shouldn't have taken near this long, but waiting on a Motor from Waller Performance for a year and then having it tear it back apart after 45 minutes of run time. Not only to find that my motor is junk but that I had been lied to. The list of problems with the original engine build would take a page all by its self.
jhacking
Hacker
Just minutes from being mount onto the dyno
jhacking
Hacker
All I need now is this rain to stop, and a little sunshine and I'm off to start some testing.
Luke
Fish sticks SUCK !!!
very nice, so how did the dyno session turn out? whens the first trip to the track and which one you think you'll go to? cause I will be there!
jhacking
Hacker
dyno went great. I will be renting a day at Moorseville, I dont know really on a date yet I'm busy racing so it will be when I get some time. I am off the Italy in two weks so I would guess after I get back from there.
graham1524
Well-known member
That looks sweet!
Ry368
Looks like some nascar boys got a hold of that bad boy........looks awesome!!!!:tup:
