I think my 6131bb is leaking oil at idle. It has done it since new. I initially thought it was te junkyard Vortec motor I installed but I don't think it is.
If I let it idle for 15 minutes (or stuck in traffic) I will see smoke out of tail pipe. I have also seen the turbo exhaust housing will be wet around the where it bolts to center section. If i just drive it the oil on housing burns off. I don't see smoke in my rear view mirror when i get on it, though my rear window is tinted. I have the correct pte oil restrictor for ball bearin turbo's, i am probably one of he fee people around here with a bb pte turbo. Is this still an over oiling issue? I do not have a high volume oil pump, I do have an aftermarket braided oil feed line. Or do I have an oil seal issue. If its the oils seal is it easy to replace? Is it bad to run the turbo with this issue?
