Q about install heads with Cometic (+)
Flint
Re: Q about install heads with Cometic (+)
So..
ARP bolts with red gel from Permatex.
80lb
Cometic just clean brake cleaner.
Thax all.
1madgumby
use lacquer thinner not brake cleaner, brake cleaner leaves A resudue.
4C FED
Absolutum Dominium
I know, but "lacquer thinner" i not find.
Uses acetone or methanol. on the block deck and head surfaces. Do not use it on the gaskets.
Make sure you wear some rubber gloves when using either chemical.
1madgumby
You can find thinner at any paint store. Lowe's, Home Depot Ext.
