Re: What fuel pump should I use
dante30
Which of the relays under the hood should I check, and what is the best way to test the relay in question? I have already checked the fuses, and they are fine. Also, Is there anything else that would make the fuel pump not run?
If it turns out to be the pump for sure, I'm thinking about running with the walbro GSS340M. Any thoughts or advice here would be great! Forgive me if my questions are somewhat overly simplistic, I'm just trying to make some sense of my dilemma! Thank you all,
Dante'
ghettosled
SYTY SUPERSTORE
check the ecm-b fuse, and if you need a new pump we have the 340m (high pressure) with wiring kit on sale for $109. typically you only need the high pressure if exceeding 70psi, but if you can get it for the same price as the regular 255 why not.
thanks
