Replacing a oil pressure switch
AZTY
Can anybody direct me or explain to me what I need to do to replace my oil pressure switch. I haven't done this before and I don't know if this is something that I can do. I think someone was telling me that its back by my cap and rotor? Help
QUICK STORM
B.A.M.F. BMW Tech
Re: Replacing a oil pressure switch
i have done this, man it is a PITA. i would suggest removing the distributer, and then walla you will see the SOB. when i did mine we didn't remove the distributer and i took a long time. good luck with your ty.
DynaGlide
Ton-Eighty
Your oil pressure sending unit is against the firewall, under and slightly to the right of the distributor. You'll want to preferably remove the distributor, but at least the cap. Prepare to lay on your motor, get grimy, and swear a lot. The part is about $18 from an auto parts store... I can't remember if it's 1/4" or 1/8"... I bought both, and returned one. I just don't remember which.
Good luck.
If you remove your distributor, it has to go back in on exactly the same teeth it came out of.
