Re: Rode in the Bully Syclone tonight!
BULLY Syclone said:
Ok you all know how much I like posting here but.....................Here are the pics of the valves that were hitting the pistons and also a piston.
If some of you would spend more time wrenching and less posting MAYBE you would be able to understand the whole odd/evenfire deal and if flanders would have taken a good look at my truck at the nats he would have seen that there is no distributor and Motec will make the plugs fire at any deg. that you tell it to.
So to clear all this up......1123 hp at the crank 10.3 146 mph and yes I have a time slip and there is plenty of video on this site showing it!
Ok, name giving again :I so Flanders it is.
Whell, at the nats we had a chance to straighten out some issues, BUT U and the team cept whell to yourself, DROP that dead horse now.
Yes I know werry whell U run a 10.3 run..
And a nondistrubutor ignition could werry whell fire AS U say on every cylinder, but still the cam timing (opening/closing of valves) should be verry much OF on some pistons and right on, to some, this would have been discovered at startup and tuning.
These damaged valves and pistons Ive seen before (not U´rs but others) and cause of that have been to tight piston to valve clearence AND over reving the engine, and to my recolektion Ur truck drove out tho the track and then did some testruns as Robert did, and it ran fine then but when U stepped up on power it missfired bad...
Though Robert did´nt drive out to track, he drove home from it instead
And about wrenching, I should do it more often, but I have to work to
I do all my and a couple of friends engine build and tune from scratch, No special builder here to mix up parts.
Robert is ONE of my friends MORE SKILLED THAN ME building engines..
I build engines in range of NA 400- 650 Hp Robert goes Boosted up to 1200+ Hp..
Regards Flanders..
