Russell brake lines
Damian
Which ones are you guys using? 672380 or 672390? The 672390 can be found on ebay right now for $50 shipped and the 672380 is just over double that. I havent seen any vendors selling and brake line kits either. Ive also looked at Kore 3, but cant find a part number for us.
blue83z
Re: Russell brake lines
I have not, but am looking to do brake lines, would love to hear if anyone makes "pre bent" ones.
Damian
I read a thread some place where they bought all new hard lines. I just want to get rid of my cracking rubber lines, especially since I have a ABS delete on the way.
sytyguy
Moderated User
Let me do some measuring and ordering and I'll put a kit together. I've been meaning to do this to compliment our ABS delete kits, but haven't had the time. My truck is on my lift anyways, so let me work on this.
Damian
Hurry up then! I need some by next weekend. This is my last "major" thing to buy, for now.
warmpancakes
the russel kit on the ebay ling is correct for 100% stock brake trucks as far as prebent hard lines sportmachines has them
Damian
I have the F body discs in the rear, and my stock lines worked perfect with them. I'll give Hood the opportunity to get some prices out first.
warmpancakes
the russel kit is 3 lines 2 for the front calipers and the third is from the frame to the diff, if you converted to rear disk then these lines should still work assuming the rest of the brakes are stock
sytyguy
Moderated User
That eBay price is a steal (same thing I can GET the kit for and I have to order it). Go with that.
atkonkler
Is this your bush?
AutoZone has nickel cad lines that are super easy to bend and are almost impossible to kink ! Look into that its good stuff!
Aaron
green73
Digging up an old thread rather than making a new one on this subject.
Went on the online hunt for the Russell 672380 line kit. May have missed the deals on Amazon and or E-bay, but for some reason, couldn't find them. I did find Goodridge 14103 line kit for the same application. A little more spendy than the Russell kits on average, but as with Russell they are DOT labeled. Wanted to stick with a DOT kit to avoid potential inspection troubles, should I end up in a location that actually looks at these things for registration.
