Re: Slowly Losing Fuel Pressure
Dropping fuel pressure is because of 4 things. Fuel pump check valve, leaking fuel injectors, fuel pressure regulator, and fuel leak I put this in order of how common I think these problems are. You should obviously will be able to smell a fuel leak. You are not going to be able to use the factory service manual adjustment of the fuel pressure with the system leaking down, plus I am not sure how accurate this is with an aftermarket full pumps, since it priming the system.
The problem with my situation is I have a brand new Accufab AFPR and when I put the key in on position the fuel pump does prim and goes to the desired level immediately starts dropping in fuel pressure down to about 20lbs than stops.. Its the reason I started this post. someone resonded saying that they had the same exact problem with there new Accufab AFPR and had a new one sent to them and it did the same exact thing again. apparently that's what Accufab regulators are prone to do. when the truck is runnin it holds pressure though..
