absintheisfun
1993 TY 0722
Okay,
so I started driving after a new turbo, chip, 3-bar map set up...and I am driving like ms. daisy...all appears to be going fine and then spark retard like crazy....
boost never even became a factor...the highest it got was -8 (yes, that is negative)
speed was very consistent around 25-35
RPM fairly consistant <2K
Spark advance would be steadyish around 35-40
and then it would drop to around 20, and the spark retard would shoot through the roof at 19.9
you can see the peaks of the retard when the advance would fall...should the advance be that high?
Thanks!
Thanks!
