I know this has been discussed thousands of times but has anyone come up with a permanent or semi permanent way to fix the squeeking? its driving me nuts
not sure if the window is squeaking in the same spot as my blazer, but mine made the same noise... all i did was unscrew the pin, wrap electrical tape around the threads, and tighten it back up... noise hasnt been back since. let me know if it works for you
What exactly makes the squeak??? The guy i bought my Ty from said it was the rear air deflector...?? Or is it the glass wiggling? Since my stereo got jacked by the cops that all I have to listen to and it's makin me nutz to!
I have placed one or two raps of electrical tape around the latch hoop and have had no more sqeeks. Makes it a little harder to shut the glass, (you can feel it) but worth it. Drive in peace
Ok, I tried a new pin, and u bolt or latch whatever its called, tried electrical tape, duct tape, and wheel bearing grease and the thing still squeaks like crazy. any other tips on how to stop this damn squeeking?
Ttake the plastic cover off the inside of the tailgate and adjust the latch retaining mechanism. Toward the front and up a bit ( with tailgate down) will snug the window down. Adjust in small increments. Don't forget those bolts that secure the window to the hinges. They loosen/distort the hinge and need to be tightened once in a while.
