I have a ty that sometimes just clicks when the key is turned,some times it will start on the first turn and sometimes it will take multiple turns. I have replaced the solenoid and still no change. I have a new battery cable (positive) that I havent installed yet! The starter has been checked out and worked fine on the testing machine. Before I replace the cable I was wondering if the problem could be the ignition switch? If anywone has had a similar problem I would appreciate hearing from you.
