tommynos
Here is the deal,I bought this ty and found it had a new motor put into this thing at around 89,000 miles in 2001 and it now has 129,000...The newer block is blue with the blow-out style freeze plugs...Im having a local guy help here in Sarasota tuning it and he keeps saying "I think it isnt the right motor and they used a stock non turbo block" this is because another guy up there has one running perfect and is stock minus the converter in his, its a bigger sthal which makes it come out of the holes harder...
I say there is NO WAY it would have lasted this long and id never be able to put the 15+ psi threw it that im doing now? It was running slower than his by far but we are tuning this thing and it now seems WAY faster since Ive done these things
New battery,plugs,wires,cap,rotor,distributor,IAC,both PCV valves,fuel filter,K&N air filter,both exhaust manifold gaskets done,new 3 inch exhaust with bullit stainless muffler, throttle body taken off and all cleaned,all vacuum lines good and all check valves proper,FP set at 45 with line off...P.S it still idles like crap
So what is different from stock blocks to ty blocks and why would it not have lasted?
Also this weekend spoolingturbo6 is adding the ostrich,walbro 255,3 bar map and tuning it and im guessing mine will be faster than the guys stocker..
