Stumped!! temporary low voltage
Just noticed an issue today driving around on errands. When I start the truck the voltage is around 8-10 volts and it just sits there for a minute or two. It idles a little rough but seems to run fine. I get a little flicker when turning the headlamps on but no drop. After a short time it jumps up to normal almost instantly and everything is peachy. Through searches I learned that the probable cause is bad ground or alternator. Grounds seem fine and alt. passed the test at local O'Reilly's. Not sure if that means much but when the gauge jumps to normal everything seems perfect.
I also noticed that occasionally, not often, it'll idle around 1500 or so at start-up but eventually finds it's way back down to 800 or so. It's done this before I had the voltage issue, Could they be related? I haven't pulled codes yet but the occasional check engine light I am sure is for various voltage drop issues.
I'll check the codes tonight to be certain, just thought I'd get a head start on what to look for when I have the time to mess with it. It doesn't seem to be a bad connection anywhere because it's everytime I start it and consistant in the length of time it takes to jump back to normal.
sy2675
He Saved the Pimp'n Game!
Re: Stumped!! temporary low voltage
the wire feeding the ecm could be bad or going bad, thus effecting running conditions, have you checked volts at the alt when the gauge is saying its low? i would check that and the battery connections for volts at both times. running good and bad, also check volts at the ecm.
Don W.
Sounds like it's taking a moment for the alt to come online. Check connections at the alt, junction block (firewall near dist.) and starter. or; if possible swap the alt out with a known good one and see what happens. That "flicker" is a clue.
kentuc
Might want to look at the ignition switch and wiring on the column for burning.
Thanks for the suggestions guys... After checking things out I never really figured it out but I am guessing that it was just low battery and the fact that the fan kicks on when turning the key. That didn't help matters much. I took the fuse out of the fan for a couple weeks and haven't noticed the issue anymore. Yes it runs cool enough without the fan. When I put it back in everything seemd to be normal again.
I'm chalking it up to low battery
