Syclone bed weight 500lbs?
Grimgrak
I'm curious as to why the syclone can't haul around more than 500lbs in the bed what upgrades need to be done in order for it to handle such loads? I'm not looking to carry that much weight on any long term basis. I'm just trying to pick up a 750lbs mill and drive it home. Would an airbag suspension help is that the problem?
sy2675
He Saved the Pimp'n Game!
Re: Syclone bed weight 500lbs?
i think its the tranny more than the suspension
jjorgensen52
NHSTE - I'm the only one!
I'm pretty sure that plenty of people have overloaded their trucks that much. The problem is that the lower springs cannot handle the load without bottoming out bigtime. Airbags will help, yes. Also, if you have a load like that be very gentle on the truck, it will be hard on the tranny. And staying out of boost is good too
Tow rated to 1,000 lbs IIRC.
Grimgrak
If it's simply the tranny thats the problem why does the ty have a load rating or 9xxlbs vs the sy's 500?
gjp
another post whore
I had about 600lbs and suspension was fine.
Stangbeater
How bout it?
Just rent a truck. It is not worth beating on the Sy. Plus you can treat it like a rental or drive it like you stole it.
jjorgensen52
Same tranny, different springs. The typhoon is designed to carry two more fat people than a Sy, hence it has stiffer rear springs. As a result of the heavier interior load, the Typhoon is not rated to tow at all. the tranny is a weak link in both but if you are careful (IE NO BOOST) it will do fine. I know there are guys on here who have towed jet skis and such things with stock trucks, I know my Ty once had a 4x4 quad in it for almost 200 miles :lol:
