LawnGnome92
I got my truck out on monday and things don't seem right with the transmission. The truck has been parked for around 6 months. It shifts soft and around 500 to 800 rpm early. It also will not perform a downshift at WOT. For example this morning on the highway at around 75 mph in 4th gear. I stomped on it and it stayed in 4th instead of dropping to third. I adjusted the T.V. cable by depressing the adjuster button and open the throttle all the way. It pulled the cable all the way to the end of its adjustment at WOT on throttle body. The cable is pulled tight with this adjustment at WOT and feels correct. But at the idle postion on the throttle body the cable has around 1/2 to 1 inch of slack (the cable slides freely inside the cable end). Is this free play correct?
