canadian
sy in progress
How easy is it to swap throttle body linkages between throttle bodies? I have a stock SyTy throttle body and an aftermarket one that I need to put the linkage on.
The aftermarket one has the linkage held on with a bolt, but the SyTy is attached to the throttle shaft and then the shaft is pressed so that it won't come off. I know I'll have to cut it off, but will the spring thing-a-majig come unwound when I take it off?
Never done this before, so I'm looking for some confidence inspiration here.
Thanks
Thanks
