Throttle body shaft leak common?
TurboRob
Junior Member
With all the recent talk about throttle bodies, I just have to ask. How common is it to have the TB leaking through the shaft?
After having replacing all my vacuum lines, removing & cleaning the TB and replacing the IAC, my IAC counts are now down to only about 7. I figure it must be a vacuum leak, but I've checked all the hoses and fittings at least a few times. Is there any way to isolate the leak if it's the TB?
Typhoon #1133
yous is at 7??????? Man, mine are around 50-75. i changed my vacume lines and one of my tb gaskets and still have a leak on the bottom of my tb.
4C FED
Absolutum Dominium
Get a squirt bottle & try spraying water onto the shaft. I know it could be tough. If it gets sucked in you know it's bad.
Otherwise try the hose stethescope method and start poking around. Listen for the hissing sound.
Another way could be to just grab the linkage and try to push the shaft left/right & up/down. If you can see & feel the shaft move, it's time to replace.
Typhoon #1133
i have a leak right behind the vacume line on the bottom of the tb. i replace the gasket on the side of the tb. so do you think this air i feel is comming from the bottom gasket or could it be something else under there that i am not aware of?
mrweelr
My TB is leaking at the shaft on both sides and my truck only has 54K original miles on it. I'm not convinced that this is a problem because the turbo should be efficient enough to compensate for such a minor leak. I don't think the stock TB's on our trucks were designed to "hold boost" as they look to be the same units as on the L98 Corvette motors. I get occasional boost spikes up to 20 psi with my stock turbo so I don't think the TB leak is detrimental whatsoever. I can also build 10 psi or more from a launch so no problems there either. To see if mine was leaking, I just removed the IC from the TB and hooked up a modified bicycle tube and pumped it up. Then I sprayed water with some dishsoap all around the TB and bubbles came out of both sides of the shaft. Unless you are having problems building boost or you can justify a bigger TB, I wouldn't worry too much about this.
sy2185
yup, mine leaks too. Moving my foot on the acc. pedal w/o actually revving up the truck(just tightening the cable up against the slack) moves the shaft in the bushing and can affect my idle by as much as 250 rpm. My theory is that the torsional loads on the shaft from pulling against the taut TCC cable and the mechanical advantage given by larger dia. throttle cable mount over the shaft dia. pulls the shaft off center after a while.
It's damn common.
Jeremy
4C FED
Absolutum Dominium
Well there is the gasket for the IAC I believe that goes under there.
It's not the gasket that goes around the actual IAC. It goes around that plate that is on the bottom. Not really sure if it has an air path to the intake.
Either that or you might have a bad mating surface on either the TB or the intake. Maybe someone used a screwdriver at some time to pry the TB from the intake.
Just some thoughts.
Hey guys, I was the original one who has noticed this problem and since then I have replaced my TB to a BBK 58mm. Before the replacement I had boost fluctuation between 11-14psi at a steady throttle.(which is now gone) My TB sgaft had movement in and out and also up and down, so it was petty lose. With this new TB there is a great improvement in throttle response. You just touch the gas and the truck flys.ohh, I also had no prob building 5-8psi while launching. Im sure every situation will be different, but for what its worth this upgraded was well worth it for me.
