Gnocide
turbo game burt reynolds
looking get some info out there and updated as well.
since Every stock TB will leak eventually
(your iac numbers will go single digits when its bad, the inner tube test will blow soap bubbles out of the side too)
what are the options?stock vs 52 vs 58 mm- which and why?
who sells them/ rebuilds them?
can you use any bbk, Holley ,summit brand and just re use your factory linkage?
nobody want to blow out a tranny from improper linkage adjustments like some had with TB spacers.
thanks in advance
thanks in advance
