Tight spaces with coil overs :(
Boostn
91 Syclone on a diet
Well, last week I finished installing the coil over suspension for the Syclone that will be getting Typhoon's donor parts.
I am concerned about how close the coilovers are next to those camber/caster adjusting bolts. See the pictures.
Right side:
Left side:
Do I need to mess with the spacers some more? If I adjust it more away from the camber/caster bolts it would probably hit the halfshafts/CV.
It doesn't have the engine/tranny/transfer case in yet so with extra weight, the position of the coilovers could change.....
I just want to hear everyone's opinions.
DOMN8R
NASTE Member
Re: Tight spaces with coil overs :(
Dave worked very hard to get these to try to line up my truck... the clearances are borderline rediculous. I'm sure he can tell you more about this and how to make it better. But I can tell you a couple things I noticed...
1) absolutely check them with the ride height settled, the geometry changes. especially since this coilover setup settles a LOT (apparently a lot more than the JS ones..). if I jack my truck up and let it down... the front will stay several *inches* higher for a little while...
2) having an alignment done can change the geometry enough to cause problems as well so you may want to do one before you go crazy fine tuning the clearances.
Dave worked a lot of his magic to help with the problems... I don't remember everything he did but I do know he grinded down the shock tower bolt for more clearance and always looked at what happens when the suspension compresses/decompresses not just how it looks staying still...
jwaller
Evil Genius/SyTy Guru
you need to shim them so they are more towards the rear and further away from the bolt.
might also want to think about getting turbotime to hook you up with a smaller diameter spring.
jjorgensen52
NHSTE - I'm the only one!
i put my shocks all the way to the back of the truck at the top and kept them centered at the bottom... clears the bolt by enough and the CV's as well
Boostn
I'll have to try that when I get everything in the truck.
As for JWaller, how much those smaller diameter springs are?
I agree with shimming it rearward, a little too close for my liking. You maybe able to gain the clearance by grinding the down the offset washer (about in half) and I took a little off the adjusting nut on that side. The will make a huge difference, when their is little room to work with.
I think with DOMN8R trucks, his tolerances were closer at the top and the tie rod as it settled. You almost want the axle to be closer (when it settles the clearance is better) Unfortuantely, you can't use a smaller diameter spring with the bilsteins, the shock body is too large.
FYI the PEP is so much harder to shim the clearances than JS's...
