Re: timing gears
Same as standard sbc. Some may screw with your knock sensor though. Do a belt drive instead. You will like it better.
John
Took the words out of my mouth...
A good double roller timing set it not very expensive and is very accurate.
Belt drives are 400 or more and won't give you alot of gain for the money.
I would never use a gear drive on anything. Noise is awful. I don't like the harmonics of them either.
Good luck,
Scott~
