well, I can speak for other brands, but when i ordered my wheels, they came with Dunlop SP Sport 8000's already mounted. This fall I needed a new set, I checked out the Michelin's (which are probably the best) but I couldnt afford them at the time, and the Dunlops do compare better than the Goodyears on many levels. I decided however to go back to the Dunlops simply cause the do rate fairly well, and are reasonably priced as compared to others. I would however take note that the Pirelli
P7000 Supersport rates better in some catagories than both the Dunlop and Goodyear, have a BETTER tread wear than even the Michelins, and are some of the cheapest I have found.
It really just a matter of your budget, if money is no object, then sport the Michelins I'd say.
I purchased my last set from
www.tirerack.com , just make sure you tell them you have a Corvette when ordering, I believe a few members here got denied tires from them cause they are not rated for trucks or some BS. I just filled in the online order form as a 1996 Corvette, and when they called me the next day to confirm it, I just said "yep, thats whats on the car now", and the shipped them out.
oh yeah, Tire Rack also has a side by side comparison reading. good luck, hope others chime in and help you make up your mind.
