Traction problems.
tbauer03
TRBOBOX
When my black Typhoon was stock I felt like it had better 60' times because I could launch with 10+ pounds of boost and never spin the tires. But now it has a lot more horsepower, a 3000 stall converter and I can't boost off the line with 5lbs of boost without the rear end kicking out a little sideways and leaving a trail of rubber. I had the wide zr1 wheels on it before but I hated the way it grabbed grooves in the road so I went back to the stock wheels with BFG GForce SuperSport A/S Tires. I haven't spent any time really pushing this truck to its full performance purposes yet but I was just wondering what are some of the first things I should look at to make this thing get off the line like a typhoon should.The drive train is well built but getting all the power to ground appears to be the weak link. Will drag radials magically fix this or do I need to start modifying the suspension with traction bars, leaf springs, bump stops etc etc?
Any info or links to past post are appreciated.
bezerk
Re: Traction problems.
i have the same problem, should be running high 10's low 11's but can't get it to hook.
front end limiters and strapped the rear leafsprings down. my 2step died the day at the track, so have not dealt with it, but i have a good feeling about it the next time
Don W.
IMHO traction bars to start with but is it spinning all 4? If it's not spinning the fronts then maybe the transfer case or front dif t is fubar???
Or the old fashion way. Add weight to the rear.
tbauer03
TRBOBOX
Before I mounted the BFGs I had old Bridgestone Pontenza's on it and it danced like it was on ice spinning all 4. The new tires have helped immensely but it still spins the rear.
wildphil
I Love My Ty's
If the rears are spinning and the fronts are not spinning. There is a problem.
It's just a six
Super Member
Using drag radials will make a huge improvement.
But if you are only putting power to the rear tires, even drag radials have limitations being 2WD, then you need to work on the suspension.:2cents:
SYCLONE#1531
'MOFOFAST
Lift bars or caltracs will do wonders + front suspension limiters. I also use toyo tq drag radials on all 4 corners.
Before liftbars
after
Toyo tq drag radials
front limiters,
blacktyaffair
What are lift bars and where did you get that front limiter please?
you can get the bumpers at mcmastercar, bolts, washers exc.
Bumpers with Threaded Hole . 1/2 20 female threads. many choices. 5 inch 1/2 in. bolt is what I used.. they offer different hardmess
http://www.mcmaster.com/#threaded-sundry-bumpers/=ghu29h
:checkit: Third page.
http://www.syty.net/forums/showthread.php?t=86351&highlight=front+end+limiters
Lift bars= traction bars, caltracs.
tbauer03
TRBOBOX
I learned quite a bit from this Whats for Launch? thread. It makes me wonder if my launch RPM is too high with the higher stall converter or if I am just having traction issues with a higher horsepower truck on street tires and stock suspension. I am thinking the later but I pulled an old datamaster file and the current one when i was spinning.
My old setup with a 2800 converter and 700R4 left the line with 7.3lbs of boost @ 3100 RPM, this was a good launch on a dragstrip with 315 rear tires. My current setup with a 3000 converter and 4l60e left with 8.7 lbs @ 3650 RPM this resulted in a fair amount of tire spin but it was in a parking lot with 245 tires. I know not exactly comparing apples to apples but the engine build was the same. Back in 2003 my completely stock truck on the dyno peaked at 404lbs of torque at 3200 RPM but stayed above 375 from 3100-3600, I assume with my current engine build that curve has shifted to higher RPMs and my launch RPM and shift points are 600 RPMS higher.
I don't think there are issues with the transfer case because I have driven it without the prop shaft and it is not that kind of wheel spin. I figure I will start with suspension stuff since that wouldn't hurt anyway before I think about a 2 step, drag radials or pulling the converter to re-stall it. Any input is always appreciated.
-Ted
