Transfer oil
atkonkler
Is this your bush?
Re: Transfer oil
It's an oil supplement....If it was me I'd call the vendor you'd like to use and ask them their thoughts on the matter....just to be safe...If they say ok....your good to go!
The Dread Pirate Fisher
Re: Transfer oil
I can't find any dexron III, all the stores I've been to only carry Dex/merc or dexron VI
What can I use? In both the transfer and trans?
atkonkler
Is this your bush?
Re: Transfer oil
Dex/merc is dexron3 and mercon....it's just a superceded name and can be used in most GM and ford applications where specified....I use a quart of dex/merc and some Lucas heavy duty oil stabilizer in my transfercase. You can use also use the latest dexron gm fluid as it also supercedes dex/merc.
