Sy-1177
Turbo Inside
Ok, i'm having an issue with the Ty and it is driving me crazy trying to figure out why it will not start! So I drove it down the street a few weeks back and it started backfiring and sputtering pretty bad so I turned it around and brought it back home. (just barely running at this point) As soon as I hit my driveway it stalled and will not fire back up. When I crank it, it sputters like it wants to start but will not. I did get lucky 1 time and it did start up for like 5 seconds but then stalled right away and nothing since. It has a recent tune-up done by me (plugs, wires, cap, rotor) and that all checks out. It has a new coil; new IAC; new starter; new alternator; new battery; new fuel filter. I pulled the throttle body and everything looks good in there. My pressure guage on the fuel rail shows around 50lbs so fuel pressure should be fine. I swapped the ECM with the Sy and had the same results. So basically i'm at a loss. Any suggestions where to look next?
