Turbo to IC hard pipe
Re: Turbo to IC hard pipe
Do this for cheap.
Or do this for $$$
http://www.sytyperformance.com/inde...facturer_id=0&option=com_virtuemart&Itemid=26
I just got a 2 inch radiator hose and then got a 12" peice of aluminum pipe off ebay. Im happy with it. Didnt really cost that much maybe $30 total. When you add in mandrel bends is when the cost goes way up.
DRUNK411
The problem is once they are on the truck they usually dont come off, but they are floating around, just keep asking, trying doind a search that is how I found mine, just searched and then wrote a unch of people. Look for a Galla pipe also, it is the pipe made by Bob Galla. Hope this helps!
shonuff
i took a good look at that and decided to be a copy cat haha i went out and got two 2foot(just wanted to make sure i had enough) lengths of 2' aluminum pipe. im either going to get a 90deg silicone elbow to attach the two pipes and each end to the turbo and IC. or do it like you have it. hope you dont mind :tup: thanks for the pic
