Twin Turbo Water/Air intercooler Custom SyTy
This is a water/air twin turbo intercooler. Mounts where stock lower CAC is mounted, has inlets on each side, outlet in center going up where hood latch is. (i ran hood pins but you could rework pipe to use stock hood latch)
These are Bell intercooler cores so not some cheap ebay stuff, custom tanks, etc. i will include the pipes i used with them (inlet and outlet). if you want to pick it up you can have the modified core support also (not worth shipping though).
$500
for $100 more i can include the tank i have mounted in back of truck.
Wilson 90mm billet throttle body with 90deg sheet metal elbow to go onto standard carb intake. $250
Qty 2 GT35 (not the R) turbos. Basically a 61mm. Single be good for mild 4.3 or buy both for something extreme. Each is good for 500hp, has fairly small exhaust housing letting them spool up rather well. T4 inlet 3" v band outlet $1100 for both or $600 each
if you send me email or cell phone i can text some pics.
Re: Twin Turbo Water/Air intercooler Custom SyTy
tb pending
pics sent on intercooler
Syclone0565
CustomMulticades.com
If deal falls through I will take this:
Thanks
Syclone0565
Did the Wilson 90mm billet throttle body with 90deg sheet metal elbow sale?
Thread can be deleted, parts are going onto the next build.
