<Typhoon 1577> rebuild or bust
TurboJunk
questionable
Well I found some motivation Friday afternoon and brought my truck to the shop so i could figure out what I'm going to do. Its been sitting since the winter of 07' the truck is in nicer shape that i remember that's for sure.
After a quick wash before the water froze i got in the building and started taring it apart.
Figured out why the stock motor i bought from a board member took a shit too... I never made a safety for the oil pickup. when i dropped the pan it was sitting in the bottom hangout.
(Note to self = weld it, or safety wire). it ran great too what a shame it only had about 70k on it.
The new motor - Its been sitting around for about a year.
Diamond Racing pistons, Eagle rods, RPM nitrated crank that i had balanced by LAB machine shop.
Your average vortec's 2.02/1.6 ported by Sagona Race Engines
Should be about 9.5:1 compression... cant wait to buy a real turbo!
The cam came with my truck when i bought it... custom grind but its similar to a 412 cam
Everything else is basically stock.
I don't what i want to do with the truck yet (Would love to trade it for a Syclone in the same condition!!!)
Im still undecided if i want to part it out, fix it and drive it for the summer, or fix and sell right away.
i want to go LSX Turbo but i dont wan to do it to my typhoon... i have a regular s10 i will try to make that happen in if i can get the $$$$ together after i sell the TY.....
but hey only the first weekend we'll see how the week goes.
TurboJunk
questionable
Re: <Typhoon 1577> rebuild or bust
its taken me so long to want to fix this things because of distractions....
my daily driver goes 12.40 @ 108mph and gets 21mpg lmao.... i love that thing
i cant lie there were a few blow ups and broken trannys with this car too but its so much fun.... 2260lbs with driver!!!!
(Hoping for mid 11's next season before i juice it)
TurboJunk
questionable
a few more pics for tonight....
This is where all the magic happens in Brooklyn, NY
that was before it went into hiding
i have almost everything to make it back to original. when i bought the truck is was missing the entire interior
TurboJunk
questionable
not a crazy amount of progress but the motors IN!
just goin thru a few parts i have trying to make a decision if im goin to use the DeQuick lower CCHE or this one a friend of mine got from MagnaCharger when he was doin his caprice.
if i dont use it im definitly selling it. with fans
Scored an ATR upper cooler 2 yrs ago cleaned it up and painted it....
still need and oil filter adaptor to put the filter on (eliminating the cooler/relocator) and i can prime it and finish the top end. hopefully be started by tuesday.
got this baby snail here old pt51 from a GN with an adaptor... it will work for now
after its running.... it will be me bothering Mike Hood for advice on tuning....
TurboJunk
questionable
110 views and not even a damn ur doing a horrible job or NOTHING! lol
TNPhoon
1of28
Damn you're doing a horrible job!
J/K. :)
Progress is looking good.
When my motor is back in, the chips going to go to Hood too for a reprogram/tune as well!
BigBadSmoosh
i didn't comment because i had nothing to say that was helpful.. you know how i'd feel about you parting the truck out...
Take your time and be methodical. I rushed a few things at the end and they all came back to bite me.
Quit screwing around modifying the econobox. I don't approve of it :D , but seriously when I was modifying my daily my project car really suffered. 1 It takes away funds, 2 it takes away time.
TurboJunk
questionable
Last week this SOB is what had me waiting 4 days to find one...
now were offically oil cooler-less
Hopefully this week ill be able to take some real pics got a camera now... but heres a few from my phone that i took today.
bored while i was waiting for parts from the parts store
M5 rims 19x8.5 up front and 19x10 in the rear test fit (i doubt ima buy them but its a teaser)
The truck should get some day light this week so REAL pics to come
Sportmachines
I kinda like the M5 wheels. I'd like to see it on the ground with fr and rear on. Might need to be painted a darker silver or black....hmmm.
Raist103
Engine Killer, iPhone Killer, Lawnmower Killer
like the m5 wheels put it on the ground for some pics if you dont mind.
TurboJunk
questionable
lots of snow today.... btwn last night and this afternoon got more done.
mounted the heat exchanger in the grille..
pump....
so far so good its starts runs.
few parts still needed if anyone has PCV FITTING for valve cover
I still need to buy
a 3bar map, have my injectors cleaned flowed rebuilt or buy new, tunning!, couplers for turbo to intercooler
piece... and the money spending goes on....
I am sure I saw the PCV fitting for the covers in Autozone or Pepboys or something.
If going 3 Bar, are you going to change injectors or the fuel pump/AFPR?
Good job man - don't sell/part it. Your daily is worth more but you won't be as passionate about your Ty :)
TurboJunk
questionable
The truck has an adjustable FPR and a 255hp already. I had a set of 50lbers in there to when I tryed starting the truck at first it would fire. Come to find out the injectors weren't opening. There's a place in new jersey called injector rehab I'm going to give them a shot and let them clean flow etc. my injectors.
The PCV fitting I need is the one that holds the two valves... the factor one.
Sportmachines
Depending on the cost to flow, clean etc your 50's, I would consider upgrading to the 60#'s. The prices have come down on injectors in general. The 60's are much more tuning friendly, newer tech, and even wider range of power capability. Just an option.
X2.
I had real problems with the 50s myself and went with 65s.
Re the valves, you mean the rubber grommet in the valve cover that holds the PCV valve in place?
