TYPHOON Forged 4.3, Precision turbo and transmission part out
riceh8r
Parting out everything 4.3 related on my 93 Typhoon.
Sold pending full payment. Set of Eagle H beam 5.700 rods with ARP rod bolts, very low miles. $350
4 SRP dished pistons, 4.00 bore. $200
ARP head bolts for 4.3 $50
ARP Main studs for 4.3 $50
Comp camshaft for 4.3 260AH-R12 good condition $175
Comp roller tip rockers, stud mount, 1.52 ratio with pushrods. $100
4.3 L35 cylinder heads, #10238181. no issues. $200
Sold - SY/TY upper and lower intake. $300
Sold - SY/TY oval throttle body. $100
MSD street fire coil $30
Sold - Solid engine mounts $25
sold - SY/TY distributor. $50
SY/TY stock fuel rail setup with adjustable fuel pressure regulator $80
sold - 4.3 SFI harmonic balancer, cert expired. $25
4.3 double roller timing chain and gears, low miles. $30
Stock timing cover $20
Stock valve covers $20
Stock SY/TY exhaust manifolds and crossover. 1 stud broken off in turbo flange, otherwise good condition. $300
Precision turbo setup including Precision turbo with CCE44 compressor cover .60ar, .63ar exhaust side, adapter to stock sy/ty manifold, Applied technologies
wastegate, all stainless hotside and downpipe that gets you past the starter. Cold air intake and filter. cold side plumbing that attaches to stock W/A intercooler. Oil
lines included.
bolt on and go, worked great. $1200
Sold - Stock Water/Air intercooler, no leaks, electric circulating pump included. $250
Sold - Turbotweak 2 stage chip setup for 91 octane and E85. 50 miles of use, comes with instructions. set up for 3 bar map and 50lb injectors. $150
sold - 3 bar map sensor. $25
sold - Delphi 50lb injectors. $150
Fresh rebuilt 700R4. less than 50 miles on transmission. good clutches, shift kit, new converter. worked awesome. $900
I may be forgetting stuff, so if you need something, don't be afraid to ask.
Prices do not include shipping.
Located in northern Mn.
Call or text (218)766-5054 for quickest response
Thank you!
riceh8r
Pics
riceh8r
More pics
Im interested in the Transmission My Trans is out on my Syclone so i want a Factory Trans. Last year it went out i pulled the pan and it looked like silver paint inside. im going to take it to a transmission shop im hoping the CASE isnt worn out. If it is worn out what do you think the shipping would be to Seattle Zip code 98370
