Re: upper A arm bushing removal
cvcsmkr said:
the upper a arm bushings i beileve are 3 piece-sleeve & 2 ends.
See, that's what I was looking for! Unfortunately I'm out of time and the arms are going to the machine shop tomorrow. I think someone should do a complete writeup of the front suspension overhaul. I don't know how many posts I read that were lacking various details and the Haynes (crap) manual sucks. Alot of posts (and the manual) left out the point that you must remove the hub to get the lower A arm off of the knuckle. After this I am really not looking forward to doing the steering box, shaft, pitman and idlers arms. Thanks for the help everyone!
BTW, just for those who haven't tackled this yet and are pulling their hair out looking for info.
Remove sway bar.
Remove shock.
Remove brakes, the calipers hang nicely on the front ground effects supports.
Remove the hubs.
I found it helpful to cut a bit off of the halfshaft stud that sticks into the hub to get the 36mm nut off of the stud.
Give the stub a few hits with a rubber mallet to loosen it.
Bust the upper and lower balljoints with a pickle fork if you are replacing them.
Remove the steering knucke.
Remove upper A arm.
Unbolt the lower a arm bolts and let it drop out of the brackets, tap (beat) them forward with a rubber mallet to get them off of the torsion bars.
Mark the upper a arm eccentrics so they will be close when you put them back on, I also marked the torsin bar locations on the lower arm just in case and marked the right and left side arms so they wouldn't get mixed up while off the truck.
As for getting the bushings out....good luck. I got the lowers out by pressing the center sleeve out with a press and then beating the rubber out with a mallet and screwdriver, came out pretty easy. I could not get the sleeves out, but I believe the would come out by using a hacksaw or sawzall and cutting them longways on the inside diameter and then beating the piss out of them. I ran out of time for that.
For upper A Arm bushing removal see CVCSMKRs post above, it seems like it would work to me.
For balljoint removal I highly reccomend an air chisel, made very quick work of the rivets, I then used a air grinder to get the nubs even with the arm and a punch and sledge hammer to knock them out. You could also wedge the air chisel between the BJ and the arm to help loosen it up after the rivet heads are removed.
Install new bushings and put everything back on and go get an alignment.
Also, I believe some mentioned in one post I read that the PST front bushing kit came with the lower AND upper bushing sleeves. If this is true I would definitely go with that kit so you don't have to worry about destroying the upper bushing sleeves. The Energy Suspension kit I got only came with the sleeves for the lower A arm bushings.
I hope this helps someone out, I have worked on alot of cars and never felt the need to post anything online because I could always find the all of the pertinent information in at least one post. If anyone has anything to add to keep someone else from flipping out while trying to do this job please add to it. Any info about R+R of idler arms, pitman arms, steering shafts, and hell, even the rear suspension would be a great benefit to this board, Thanks again for all your help.
Larry
