mortgageman
Has anyone simply used the 4wd front prop shaft and pinion flanges instead of the Gilbert shaft?
I've spent a lot of time reading through all the threads about how weak the stock, front prop shaft is. In viewing all the pics of the Gilbert shaft, it appears to be equivalent to a 4wd shaft. I'm nearing the completion of a 4wd to AWD conversion on my 94 Blazer and considering just swapping the two pinion flanges and using my 4wd shaft with new u-joints. My local Clutch Products rep confirmed this would be better than the stock and that they would install heavy duty u-joints and re-balance the shaft for me at a cost of $105 including tax. That's about one third the cost of the Gilbert shaft. I'm using the offset oil filter adapter as suggested by JTR, and using the 4wd front pinion flange will give me additional clearance with the oil filter. It also gives me more clearance between the A/C evaperator housing and the passenger side exhaust manifold (Camaro LT1, early 90's) by NOT requiring the engine offset toward the passenger side. This setup looks like the perfect solution to me and I'm just wondering if anyone else has used it.
