Dr.Evil
Addicted to Boost
I sealed off the inlet hose and pressurized the intake system w/ 10 PSI with the motor off w/ my air compresser. Anyway, I found a big vac leak at the hose fromt he upper IC to the Throttle body. I tried re-aranging the clamps, changing the hose around, tightening the clamps down to the max, and nothing seemed to work. The intake should hold 10-15 PSI without hearing any leaks, right?
What should I do to fix it? it seems like it is leaking on the under side and on the top, under where you tighten the hose clap down. I don't want to make an RTV mess and can't think of any other way to fix it. Has anyone else had this problem?
