RSpengler
Ghetto Fab Specialist.
I read somewhere that on vortec heads, the retainers crash down onto the valve stem seals with more than .465" lift? Is this true, and how do you cure the problem? My vortecs are at the shop being assembled as I type and I need to know if I need to call off the build, before its all assembled... Im going to be using the comp 412 cam, and stock height springs and stem locks, is all well or no? Also, the springs I am using are Crane springs with an inner damper, I also just read teh damper must be removed to accomodate the seals??? Argh....
-Rob
-Rob
