Weird noise with vid
Sean Krupa
Moderator
Re: Weird noise with vid
turboj91 said:
Seems to be something rotational. Noise starts when under a load. As brief as the noise is, it seems to get "faster" as the rpm's are rising and then quickly slows down when you let off the gas. Loose converter bolts is my opinion. No flex plate noise from when starting as the flex plate itself is still tight. Upon deceleration, when you hear the noise is the transmission down shifting?
Can you feel this in the wheel or your feet?
We have the same exact problem in our Ty. When it's in neutral and you give it some gas you can feel something grinding and goes up with the rpm's. When I'm in the passenger seat I can feel some vibration against my foot from the transmission. Upon deceleration, the grinding gets worse. Once the rpm's get above 2,500 the noise seems to go away. I highly doubt it's the driveline, I think it's something internally.
Sean
Don W.
Well like I said, I think my truck is haunted. After dealing with this noise for a couple of months, finally borrowing a camera, getting it on vid and posting it the noise has gone away. No explanation, didn't hear anything fall off the truck, nothin'. Few test pulls today in prep for racing tomorrow, nothing. I think my truck is doing a good job of making a total ass of me. I'll see if it returns tomorrow at the track, where it started BTW.
Flyin Ryan
hated cuz he drives fords
Only idea I would have is the gilbert propshaft making contact with the range selector.. mine has done it in the past under brake boosting... other then that I have no idea but I can say that your truck is really quiet
Don W.
Early on I checked the cat and nothing loose as far as I can tell. Trouble is the noise, whatever the damn thing is, or was, sounded for all the world like it was inside the cab. It was that loud and clear. Not muffled or deadened like a sound would be from outside the cab.
And thanks but the truck is fairly quiet until you get on it. That's what a cat, no muffler, with side out (ahead of the rear wheel) exhaust sounds like under part throttle. I think it sounds pretty good but others have said they didn't like the no muffler sound.
vinnieTy
TY # 1889
I had the same issue but not in my TY. I had an older 528e bmw and when i would drive it hard and rev it out i was getting the same noise. The issue was a GUIBO. It was a rubber bushing on the drive shaft. I know the typhoons dont have them but that sounds more like something that is rotating then of rattling. Did you think about looking at the tranny mount? Maybe under load the tranny is twisting a little bit to much and forcing the driveshaft to hit. Just an idea. Good luck finding the issue and please keep us posted.
WyoSyclone
Hey Don, someone else may have already mentioned this but did you check you jack behind the seat??
Sean Krupa
Moderator
My dad found the problem today. It turned out to be the alternator which the bearing is going bad. The stiffness of the alternator must of caused the harmonic balancer to have more tension and cause the noise. Luckly my dad still had the stock alternator and spun freely. We are looking around to find a place to rebuild our chrome one. Hope this helps.
Don W.
Hmmm, The jack. That's different, I'll check that. Had the alt off recently for a test/verification of output etc, and all was well there. Trouble is now the stupid noise has gone to where it came from; outta nowhere. :roll:
Don W.
Nope the noise disappeared and hasn't come back. Truck is runnin' well (12.9's) and the trans hasn't fallen on the ground. So who knows... Geez.
