Hey guys with the 10n1, what fuel press. should I be running, using the walbro 255? Thanks
L LandryPoole New member Jun 7, 2006 #1 Hey guys with the 10n1, what fuel press. should I be running, using the walbro 255? Thanks
jwaller Evil Genius/SyTy Guru Jun 7, 2006 #2 Re: What fuel press. to run? what injectors? if stock then 50 is your number. if you have 50# injectors then 30-40psi is close.
L LandryPoole New member Jun 7, 2006 #3 Re: What fuel press. to run? stock, and I was thinking 50, but thank you for the reply.
jwaller Evil Genius/SyTy Guru Jun 7, 2006 #5 Re: What fuel press. to run? TYGUY said: is that with the vac line off? Click to expand... yes this is the only way to set fuel pressure. otherwise everybody is on a different scale. with the line off we can all talk about the same thing.
