I own a 93 ty that recently stop running. I drove it to work and it ran fine. When I got ready to leave, it would turn over but not start! I did a spark test, it sparked like the 4th of july. I sprayed some starter fluid in intake, it ran for 3 seconds and cut-off.
I'm now assuming it is the fuel pump or filter or both. I am running nearly stock except for stg 10-1 chip, and 3" exaust. When time and $$ permits itself, I plan to upgrade the i.c. pump, plumbing and CCHE.
Should I put a stock type pump back in or one that will give a little more fuel pressure. If I do this, without upsizing the injectors and map sensor, will I damage anything? What pump, part no. and size should I run with? Any advise would be helpful at this point!
Dante'
Dante'
