What tires to get
psycho1
All hyped up on MTN DEW
So after going back and forth trying to figure out what rims to get because the stock ones I have are messed up I just bought another set of stock rims. But what would be the best tires to get? I am not going to drive the TY during the winter or when it rains so it would be for the track or a weekend driver. Let me know thanks
Treymen
Re: What tires to get
Cheap=Nexen N300. very good for dry driving
More money= Continental Extreme Contact DW. Highest rated tire in nearly every category
Try Me
I just ordered the new NT05 Nittos for mine should have them by the weekend ill let you know what I think. Mine is the same way dont drive in winter weather and only in rain if I get caught out. I drive it mostly on the street with some weekends at the track.
BFG Drag Radials (255/50/16) on all four corners.
I was researching this a lot before making my order. All of the big tire company reps I talked to (BFG, Mickey, & Nitto) told me do not run a drag radial on the front if you do any amount of street driving. They wear out way too quick, and the wrinkle wall effect (not so much on BFGs or nitto nt555s, but the nt05 and et streets) make for poor handling up front.
Brassmonkey
Cruzin' Mel Man
I had Sumitomos 245/50/16 on all 4 corners and had a best of 1.63 in 60'. I changed to 255/50/16 BFG's g force tires and slowed down to 1.75 in 60'. Also, the Sumitomos lasted a LONG time. The price wasn't bad on the Sumitomos too.
BoostedSUV
X2 on Sumitomos. I had a set on my stock wheels, and currently have a set on my Z06 wheels. Nice looking tire/tread pattern, they handle well, hook nicely (1.69 60ft), and are reasonably priced.
psycho1
I think I am going to check out the sumitomos where is the best place to get them from any deals going on anywhere?
And that was the only change? No wonder you slowed down. A taller, wider tire will obviously weigh more. Don't forget that it's taller, effectively changing your rear end ratio to a taller gear, or a gearset with a lower numerical value. It's basically going to be like replacing the 3.42s with 3.36:1 ratio set. You launch a little slower. I'm sure that .12 could easily be made back up with the proper tire. You may even be able to improve upon it.
BMFB
Not to scale
I like my BFG G-force tires alot, they weren't to pricey either
Brassmonkey
Cruzin' Mel Man
I lost time in my 60' because the tires were spinning.
BTW, I am not going to do the math, but I do not think that going from a 25.65" tire to a 26.04" tire will change the gear ratio that much to affect my 60' times a full .1
pontiacws699
M/T Drag radials!! Had them on my t/a and its gone 1.65 60ft in a 6sp!! The guys on the GCSRT8 forum run nittos on all 4 corners and seem to love them.
Try Me
Just mounted up my NT05's today
ziembic
I used to run Nitto drag radials on all four corners of my 96 camaro and that was the cats a$$. The certainly wore like a set of drag radials, but it was worth it for the traction. We run such low profiles tires that there shouldn't be any real side affects other than 10 to 15 thousand mile tire life.
Brassmonkey
Cruzin' Mel Man
Don't know, but some tire engineers thought it was a good idea :dunno:
That was actually a rhetorical question, I know the answer. It is for safety reasons; to channel water out from under tires, especially wide tires
Foot Performance
I am running the continental not sure of the series they are directional but they seem to have good grip mine will probably dry rot before they wear out but I don't drive the truck very often
My buddy put the same tires on his wides DD and she only got about 20k out of them
