Double12
AstronautCowboyMillionair e
I need some help from veteran engine guys here. Shortly after my rebuild (with boneyard L-35 head upgrade), I have overheating problems and it ends up that the cylinder head is cracked in the #1 chamber all the way across the dome. So I replace it with another boneyard L-35, have it magged and decked and the whole nine yards.... well immediately upon startup I get the white smoke from the tailpipe, though not nearly as bad as before. Still getting the classic pressurized cooling system and overheat, and now #1 and #5 cylinder seem to have antifreeze signs on the plugs. The deck on the block was checked while at the machine shop getting bored .030 over for initial rebuild. Anyone have any ideas as to what could be causing my chronic head problems?
Many thanks,
Dan
Many thanks,
Dan
