Who has Alkycontrol? (Enter)
Re: Who has Alkycontrol? (Enter)
Here is what Don Julio had to say about it. This is for future alkycontrol users.
Two things come to mind. One is the pump has a check valve and a valve. If any of thosehas an issue the liquid will drain back through the pump. In other words liquid should not flow backwards through the pump. I have seen trash get into the check valve cuasing it not to seat.
Then voltage. If your seeing at least 3.5-4.0 volts. It should prime up fast unless system is dry.
Understand the test button only send a small voltage as it simulates the system activating under boost. Not the pressure seen at 30 PSI boost.
So.. confirm voltage applied to pump. If that is correct, then its time to look at the pump. In other words if you have the Initial turned down and it applies 2.5 volts to the motor.. then the motor will be slow to respond. So the voltage check across the red/c\black pump wires is the first thing. If it is low.. turn up the Initia. And retry.
BoostedSUV
what is the best kit to get?
I have an SMC kit in my truck. Very simple kit to install. Works very well, haven't gotten to a track yet to test the results but I can feel it working when I get on it just driving around...
1madgumby
Do you have A pic or two of the SMC kit?
Yeah the check valve seal was shot. It was like that since it was new. I sent it in and alkycontrol replaced the valve for free. I just had to pay shipping both ways.
attackdog
I am running the SBC Alky Kit on the SY and love it. How do you purge you setup? Is it like Nitrous were it sprays out by the hood or are you using the "Test" button to do it? Thanks.
-Dean
