Found a set of wheels, 18by8 for the fronts and 18by10 on the rear.. The rear offset is 14mm which should work great, but I'm worried about the fronts which are 35mm. Any thoughts?? Please help..
Also note that a 10" wide rear with 14mm offset will be centered in about the same place as the stocker. The inside edge will be in 1" and the outside edge will be out 1", compared to the stock wheel. So I guess it depends on your definition of "should work great"... Most people wouldn't want the rears sticking out an extra inch.
