I'm looking for a ZR2 front sway bar. They are larger than stock at 33mm. Lemme know! :tup:
NJSERRANO New member Dec 19, 2012 #1 I'm looking for a ZR2 front sway bar. They are larger than stock at 33mm. Lemme know! :tup:
jeepruby04 New member Dec 19, 2012 #2 Re: ZR2 front sway bar 33mm I believe these are wider than a sy/ty, pretty sure they mount to the a arms differently also.
B bigmileage Member Dec 19, 2012 #3 Re: ZR2 front sway bar 33mm Look for a 94 bar, the 95-up trucks used a link and didn't mount under the lower arm. The 94 ZR2 was rare and only available in a reg cab.
Andrew S New member Dec 19, 2012 #4 Re: ZR2 front sway bar 33mm I was under the impression all +98 blazers had the 33mm bar?
