Brwndrvr05
Im having an overboost issue when at WOT and making the 2nd to 3rd gear upshift shift. If i do not let off, i will see as much as 18psi and have no doubt i will see 20psi if i stay into it. Something is not right! The TY is mostly stock except for all the reliability mods and upgraded trans cooler, deep trans pan, 255 fuel pump, IC hoses upgrade, and IC hot wire. Everything else is all stock, stock 2 bar map and stock chip.
Im seeing a bunch of knock when the overboost happens on the 3rd gear upshift and i know its because of the 2 bar map not being able to read boost past 15 psi and computer wont compensate for higher boost levels. Also did some data logging with tuner pro but cant figure out to take log and post it here.
Im not seeing a check engine light or any codes for the overboost.
Any ideas on my issue is greatly appreciated. Thanks in advance
